brake lights...bah
  • Spiff325iS
    • Jun 2004
    • 1263
    brake lights...bah
    Brake Check light comes on. When my brake lights work. And then it comes on when they dont work, and all the bulbs are fine. I checked the switch under the steering wheel where that BING BING noise comes from when your door is open. And everything is good. SHould i just about replacing all the bulbs anyways? i checked the fuses, and they are all good, i replaced the ones that could be related to the problem anyways, and the Check BrakeLights still comes on, evne if some of them are working...
    any help would be appreciated.
    The Red Dragon V.5 1991 318iS / 2013 F800GT
    "You gotta fix the nut behind the wheel before you fix the bolts on the car"
    • 34839
    it's the brake light switch under the brake pedal. cheap part, easy to replace.
