Choking/trembling and starting issues
  • KBMW222
    • 340
    85 E30 325e
    Just recently car started having issues in the 2500-3000 RPM's at approx 70mph. Car wont go any faster and just starts choking and trembling. I reduce speed and try to go up again and it does the same problem.
    Exited and was in 2nd/3rd gear doing 40-45mph once it hits that RPM it slightly chokes.
    I got home safely and 5 minutes later when I went to move it, it would not start. Periodically I have had the starting issues since my car sat for a good 6 months. The battery seems good all the lights and the HID lights shine brightly. It's struggles to start, sometime does that clicking sound, and then after a few tries it starts.
    Am I having issues with the fuel line?
    Any help would be good, thanks in advance!
    Kevin
    85 325e | 88 325i Cabrio | 90 M3 | 96 Porsche Carrera (993)
    That sounds like either a fuel delivery problem (clogged filter dying pump) or a problem with the AFM. The suite of fuel system tests in the Bentley manual will reveal any fuel system problems.
    • KBMW222
      • 340
      Thanks for the help! I started it up and idling was going up and down as usual (ICV I'm assuming) then after 5 mins it died. I had it towed to my trusted mechanic and sure enough it is the fuel pump or the secondary pump. I assume it's best to replace both. I have no complaints considering I have well over 245k on the clock it's just these repairs always come at a bad time. I might let my E30 rest up for a bit and get a DD Honda Civic we'll see but thanks again for the prompt and accurate response.
      Kevin
      • KBMW222
        • 340
        Looking into this tomorrow, cars been sitting too long and I need this ready for Bimmerfest. Any other tips or is everything covered?
        KB
          Replace the high pressure pump and filter nd go from there. With luck, that will be the complete fix.
          • txtorquemade
            • 1758
            Think I need to do this myself to my 87 is. How much for pump?
            sigpic 1987 325is
            • KBMW222
              • 340
              TNG is the BEST!!!!! Car's done Thanks Armen and John
              Kevin
                • 37833
                Kevin
                Hey Kevin, saw your car down there. Sorry I didn't get to say hi.
                Matt
                Grover Beach, California
                BimmerHeads.com
                • nasty50
                  • 36
                  Kevin
                  so what was the problem?
                  • IRON-E
                    • 16548
                    +1
                    @IRON-E30 aka Edwin:D
                    • KBMW222
                      • 340
                      Originally posted by IRON-E
                      +1
                      hahah i didnt even look at the receipt / invoice... It was the main fuel pump if i remember correctly!
                      Kevin
                      • nasty50
                        • 36
                        Kevin
                        Chocking yes but I don't see how that will cost you to have a clicking sound when you start it instead of a cranking sound.but hey aslong as she good iam all for that.thanks....
                        • Norwegiandane
                          • 110
                          Yeah, still sounds like the starter is on the outz.
                          You're entitled to your own opinions, not your own facts.
