I'm looking for a replacement fan switch for my 1991 325i that's a direct replacement for the stock one in the radiator, but comes on at lower temps. I want to keep the 2-speed functionality, but I don't mind a little solder and shrinkwrap action if I need to change connectors. The stock one is rated at 91/99 deg C (low and high speeds), and I'm looking for one that's around 85/92 degrees. Again, I want one that will thread into the radiator tank without modification. I know there's lots of universal aftermarket stuff out there, but I'm not interested in that. Anyone?
Low(er) temp fan switch
Tags: None
I have done this to all of my e30's. IIRC it is the temp switch used on e36ti's.what you did to this car is like getting a supermodel naked and willing to do anything you please. now here you are faced with ths once in a lifetime opportunity and then you squander it by making her fuck you in the butt with a 24" strap on. you are a sad, silly little boy.Comment
This is what I ordered for RM european when I did mine:
61318361787 Temperature Switch in Radiator 80/88 deg. C
I put in a full electric setup so my situation was a bit different, but really the only thing I think that most would run into would be, having to change the connectors on the wiring harness, 10 min job.
