Batteries for SI Board?
    Well I finally have my 5 speed done, and my SI batteries are dead so i have no tach, Mpg, or temp guages. What are the best batteries to get? Do i have to order them or would radio crap have 'em?
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    Re: Batteries for SI Board?
    Kyle
    Depends on what type your SI board has- if it's the original board, you should have "AA" size batteries, and you can use almost any "AA" size rechargeable NICAD batteries (make sure you charge them up before you install them).
    There is quite alot of info floating around about this, do a search on this or some of the other BMW sites for more detailed info.
    Bret.
      Radio Shack sells a set, forget which model number though. They have the solder tabs on them and are pretty close to the right mAh.
        I went to a battery store to try and find some, and I ended up getting some from a cordless phone battery. They work fine.
          I wired up an external battery pod for my friend's 318is, when they die again he can spend $3.00 on some new AA's without even having to open the gauge cluster. of course your average DIY'er probably won't be able to wire it up properly. but if you think you can I'd go that way, then you never have to worry about it again.
            Did you just mount it in the space below the cluster? Or in the glove box somewhere? Im curious about the external battery idea, very clever....
            Kyle
            DILLIGAF
              Probably just an external block above the knees. How long do new batteries last?
              Keep it slideways!!
                yeah, it just sits inside the cover above your knees. no idea how long they last, but it's been over a year and they're still working.
                  does the SI board have anything to do with the tach?
                  Russell
                  1987 325is
                  1992 240sx coupe
                  1994 525i
                    does anyone know?
                    Russell
                    1987 325is
                    1992 240sx coupe
                    1994 525i
                      yah no SI board=no tach
                        Genious! I should do that, one of these days when I finally take out my slowy dieing cluster.
                        Sold it.
                          I lost all my guages, but I replaced a fuse and brought my tach back up. You should check.
                          WTB m50 or s50 swap parts, PM me
                          I call her Jenny, pics coming soon.
                          Now with Eibach springs and bilstein sport shocks
                            thanks guys
                            Russell
                            1987 325is
                            1992 240sx coupe
                            1994 525i
