Fan clutch remove PITA
  • Massimo
    • Jan 2008
    • 3207
    How the hell do you get the dam fan clutch off??? I have tried pulling the v belt tight, and jamed a screw driver between the pully and the timing chain cover that did not work. The pully just keeps slipping on the v belt.
    Is there another way to lock the pully. It is a 318is.
    Thanks
  • Jean
    • 18228
    Use the special tool if you can't wedge a long screwdriver between the bolts that hold the pulley to the wp and turn the nut with a thin open end wrench... it is reverse thread.
    • hotballs
      • 1155
      Torch, only way mine came off.
      • ron1999
        • May 2007
        • 122
        i used a hammer and a flat screwdriver...
        • Erick
          Official R3V Drifter
          • 11169
          Quoting to emphasize this point.
          ..::Support FullOpp::..
          FullOpp Stickers for sale!
          Feedback Thread
          • Knockenwelle
            • Jul 2008
            • 395
            I had good luck with a large 1 1/4 wrench on the nut, and whacking the wrench with a hard plastic mallet to crack it loose.
            And again, it's reverse thread. So hit to your right when facing the car.
            Mike
            '91 325i track car. Mostly...
