will the cluster from an m3 be plug and play with my motometer late model cluster?
m3 cluster...
no.Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/ -
Tach will not read accurately
Oil temp wont work at all
Water temp *should* read properly
Speedometer will function properly.
Fuel gauge will not read accurately
Specific enough?Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/Comment
Fuel Guage reads fine on my 12 gallon ETA Tank, Temp works fine, Service lights work fine, Speedo works fine, Tach is off slightly (going to get it recoded) and oil temp does not work (*need to wire a sender in place, easy stuff*)
picture of it in use on my ETA
so for instance, while the tach reads 4000, I am really spinning 3000
everything else is fine
Why did you ditch the accurate readings of the eta cluster for inaccurate readings from an m3 cluster?
"It's like a koala bear crapped a rainbow in my brain."
R.I.P. Harry Goz aka. Captain Murphy
"My ride, My ride, she don't beg, steal, cheat, or lie,
My ride, My ride, and our relationship is classified."Comment
Because anything M3 is cool of course. Who needs accuracy when you have that little m-logo in the center of your instruments. It add's 1000 RPM you your engine too! :roll:Originally posted by cahomeyWhy did you ditch the accurate readings of the eta cluster for inaccurate readings from an m3 cluster?Comment
who actually uses the tach to shift by? I just look where the needle is or tell via engine noise.Originally posted by cahomeyWhy did you ditch the accurate readings of the eta cluster for inaccurate readings from an m3 cluster?
I bought the cluster because when I do my 2.8L Turbo I want a tach that can scale up to 7200rpm's if I desire. Plus I can use the factory oil temp gauge
You have to put in a 6cyl coding plug for it to work properly,
remove the black front facia below the glass and you can see the coding plug,
install one from the same model year as your car,
I would kill for a 8k tach, cause I need one ;)Gunni
@ Prodrive / Aston Martin RacingComment
it still won't read correctly, you will need to have it recodedOriginally posted by gstuningYou have to put in a 6cyl coding plug for it to work properly,
Sound is a good and fun, but when your in the "grey" area before you hit redline it's nice to know exactly where your at.
and 6200rpm indictated on my tach is fuel cutoff, so I know where I'm atOriginally posted by cahomeySound is a good and fun, but when your in the "grey" area before you hit redline it's nice to know exactly where your at.
