Speedometer Trouble
  • e30Matt
    • 5077
    I'd find another working cluster and swap it in. Sounds like an SI board problem.
    • redbull 325is
      • 7472
      no if it is affected by temperature, re-flow the circuit board of your speedo, i had the exact same problem and that solved it. Over the years of warming up and cooling down the connections expand and contract, until all of a sudden on breaks. This is why it works when its warm, it expands and makes contact. anyways, just get a cheap soldering iron, and some solder and go over each connection on the actual speedo board.
      Julien
      Build Threads:
      • EverWiser
        • Aug 2004
        • 313
        Julien
        ^^^^What he said...^^^^
