Oil pressure warning light on, need help.
  • Gonzo318is
    • Sep 2004
    • 88
    This weekend I changed the oil and filter on my recently purchased '91 318is. The problem is that the oil pressure warning light won't go off. Yes, I made sure the the drain plug was secure before refiling the oil and the same with the filter. Yesterday when I started the car the light would turn off as it should then after a couple minutes it would turn on and stay on. This morning I checked on it again and it didn't turn off at all.
    There are no leaks, the oil level is perfect right on the "full" line, and all bolts/plugs in relation to the oil are secure.
    So I know it's not 1. the oil level/a leak, or 2. it's not the idle speed because the light doesn't go off while driving when the idle speed is increased.
    What could it be? If it's something simple like a swithch I find it weird that this happened only after I changed the oil. Any help is appreciated.
    • 34844
    could just be a bad level sensor.
    • Gonzo318is
      • Sep 2004
      • 88
      Is that the name of the part, "oil pressure level sensor?"
        • 34844
        er that's what I meant, oil pressure sensor. it could also just be grimey, although it's a cheap part it might be worth it to try cleaning it up first and see if that fixes it.
        • nickmp0wer
          • 1427
          i wouldnt be driving like that
          • Gonzo318is
            • Sep 2004
            • 88
            Yeah, I'm not driving it right now.
