picture request
  • Bryson
    • 1490
    picture request
    ix front subframe. I want to see what one looks like, and possibly an ix m20 with motor mount brackets attached, or just the motor mount brackets themselves
    thx
    -bryson
  • kansas-ix
    • Jan 2004
    • 1600
    Got you covered check back this afternoon for pics
    E30 325ix 62k
    • Bryson
      • 1490
      sweet, thanks
      • Matt86es
        • Aug 2004
        • 616
        This isn't exactly what you're looking for, but thought it might help...
          • 34839
          are you thinking of buying an ix, or trying to use an ix subframe in a RWD E30? if the latter, good luck. the ix subframe attatches in a different spot (further forward, the ix unibody is different). the steering rack (which is different) goes through it, and also the control arm mount is different (uses a larger ball joint) and also in a different location.
          • Bryson
            • 1490
            http://www.theeurodepot.com/usede3031.html
            that did help, It's not enough to do what I wanted :(
            • kansas-ix
              • Jan 2004
              • 1600
              sorry it took awhile:
              Front 3/4 profile:
              tops side:
              bottom side:
              Motor mount:
              Mounting bracket:
              E30 325ix 62k
