i need a new set of fuel injectors on my 89 325i and need the cheapest place to get them. i found the partsbin.com has em for 40 a piece but i'm lookin for cheaper if anyone knows thanks.
i've got the 19lb injectors in there now but don't have the money to get the m30 afm so right now i'm just wasting alot of gas. i used to have a set of stock ones but my dad accidently threw them out. he's buyin me some new ones but i'm just tryin to find them as cheap as possible.
**hotghias - are they in good shape. like i would need em close to new. if they are then pm me or post. thanks
by cleaned do you mean the outside of em or are they startin to get clogged? is there a special cleaner to use with em. also, would i need to get a new set of the injector seals or are they still good on those.
Really? What's your gas mileage? I would think that the oxygen sensor would automatically correct the air fuel ratio so you wouldn't use any more gas, except maybe at wide open throttle.
the injectors i have came with my "i" intake manifold, and i will not be using them. i have never run them, so i am not positive they work or not. of course, i've never seen an injector completely fail, just get gunked up. i think your best option (much better than paying $40x6=$240 for new ones) would be getting your old injectors cleaned, or buying the used ones from me or rwh, and getting those cleaned. lemme know if you want mine.
