Transmission seals.
  • Sean
    • 5793
    Transmission seals.
    Alright,
    I need some pointers here. I'll be picking up a 30mm socket tomorrow for the output shaft seal.
    But, I was trying to work on the selector shaft seal, and I really am not sure how I'm gonna go about getting it out?
    I can do everything but get the seals out. I don't ahve a puller, and don't really wanna buy one. So, what;s the next best thing?
    Thanks for your help!
    -Sean
    - Sean Hayes
  • Sean
    • 5793
    Does anyone have anything to offer? I need to get these replaced soon...
    Thanks.
    - Sean Hayes
    • mikeedler
      • 6707
      a small screw driver and a hammer. knock a hole through it and pry it out very carefully making sure not to scar the trans.
      • bimmerphile
        • 3495
        yup.
        From the hayne's manual:
        "Pry out the selector shaft seal with a seal removal tool or a small screwdriver. Make sre you dont damage the seal bore while prying out the seal."
        • Jordan
          • 12916
          They make seal puller tools... they are very cheap, and they *work*
          Any auto parts store should stock one.
          Using a screwdriver is risky. If you scratch the metal sleeve the seal presses into it will leak.
          https://mtechniqueabs.com/
          • Sean
            • 5793
            So, schucks should have one then too?
            I was thinkin it was a BMW specific part, but if not, I'd consider buying one elsewehre.
            When you say they work - you mean they aren't risky then, correct?
            Thanks guys!
            -Sean
            - Sean Hayes
            • bimmerphile
              • 3495
              schucks will have it, work = less risky than screwdriver. naturally, you can still mess it up.
              • Digitalwave
                is a poseur
                • 6300
                Pretty sure that 30mm socket needs to be a deep socket and thin walled as well, just so you know :)
                RISING EDGE
                • Sean
                  • 5793
                  Thanks, that's what I was thinkin. I'll need to find one tomorrow.
                  Thanks!
                  - Sean Hayes
                  • James Crivellone
                    Head Janitor
                    • 6305
                    Thanks!
                    This tool was the hardest to find when i was looking.
                    What I finally ended up doing was going to autozone, buying a cheap deep socket 30mm and grinding it down until it fit.
                    worked fine
                    • Sean
                      • 5793
                      Thanks!
                      worked fine
                      I've realized the same thing, and I think I will give this same thing a shot.
                      How'd you go about getting your seals out? Someone else suggested that I get a type of screw driver with a hook on the end or somethin like that?
                      Thanks!
                      - Sean Hayes
                      • rumatt
                        • Dec 2004
                        • 93
                        Bump
                        I'm going to be replacing my guibo next week, and I'm wondering if I should replace the two accessible transmission seals while I'm in there (output shaft and selector shaft seals).
                        It looks like I'll need a seal removal tool and a 30 mm socket, huh? (sigh.. every job seems to require a new tool) Do people normally replace these when they're in there, or just wait until they leak/fail?
                        Thanks
                        • Sean
                          • 5793
                          Those rear ones are usually ones to wait to fail - since if they leak, you can replace them fairly quickly and painlessly.
                          I could NOT, for the life of me, replace the selector shaft seal after I started screwing with it. So I paid a local tranny shop $30 to replace it for me. (I brought the tranny to them) I had the other seals, but left them alone (probably should have just had them replace all of them). Teh 30 MM DEEP socket is VERY hard to find.
                          But, when i was talking to the mechanic at the tranny shop - he basically told me - if it isn't leaking - leave it alone.
                          So, unless you have some major leaks - they should be fine. I think the seal to worry about the most is the input shaft seal.
                          - Sean Hayes
                          • rumatt
                            • Dec 2004
                            • 93
                            Thanks Sean. I think you convinced me to leave them.
