Removing Center Support Bearing.
  • Sean
    • 5793
    I've been having some trouble getting the old center support bearing off. I have a new one here, and the drive shaft seperated - but how do I go about getting that circlip off? Does anyone have any suggestions?
    Thanks in advance! :D
    -Sean
    - Sean Hayes
  • Jordan
    • 12912
    Use a pair of circlip pliars. They are designed for removing those...
    After you get the circlip off you need to put the driveshaft in a press and press off the old bearing/press on a new one.
    https://mtechniqueabs.com/
    • BS87
      • 1606
      I've always been a bit unclear on that one- Does the new bearing have to be pressed on to the actual driveshaft, or just into the mounting sleeve thing?
      • EverWiser
        • Aug 2004
        • 313
        Not to be too much of a "smartass" but, if you've got any mechanical ability, shouldn't it go back together in the reverse of how it came apart? Also, not to be a broken record BUT, what does the Bentley manual say?
        • BS87
          • 1606
          Well, seeing as how i've never take on off or had to replace one before.....
          • BS87
            • 1606
            • Digitalwave
              is a poseur
              • 6284
              You just slide it on.
              RISING EDGE
              • BS87
                • 1606
                Thanks.
                • Sean
                  • 5793
                  Believe it or not, I went to a driveline place here in Boise, and I was told they'd charge my $30 for the job. Brought it in, five minutes later, the dude brings it out and says just to take it. Lol, it was awesome! ;)
                  - Sean Hayes
