How Much Lbs? Injectors, Fuel Pump/
  • ZiMMie
    • Jun 2004
    • 968
    jst wonderin how much lbs does the stock injector put out? am think of pickin up a set of Mustang 5.0 19lbs.
    2. question How much lbs does the 318i fuel pump pumps out. and wat about the 325i Pump.
    thanx in advance.
    www.stancefactory.com
  • Digitalwave
    is a poseur
    • 6292
    I believe stock 325i injectors are 14 lbs/hr. 19 lbs/hr is probably overkill unless you get an AFPR.
    RISING EDGE
    • ZiMMie
      • Jun 2004
      • 968
      wat if i have 2.7 buttom end will i still need Regulator?
      • Jand3rson
        • 37587
        Size of the block has nothing to do with it.
        • Digitalwave
          is a poseur
          • 6292
          Is it a stock eta engine? Why are you running out of fuel?
          RISING EDGE
          • ZiMMie
            • Jun 2004
            • 968
            well am buildin a 2.7stroker so am thinkin the stock 14lbs injectors will not be enough.
            • bkelsey86
              • 1173
              19lb injectors are all you need for anything short of a Turbo.
              • ZiMMie
                • Jun 2004
                • 968
                ^^ can u explain please?
                • Jand3rson
                  • 37587
                  Your engine won't need any more fuel than what the 19# injectors put out.
                  • ZiMMie
                    • Jun 2004
                    • 968
                    damn i guess am gonna be usin my stock injectors. wat about fuel pump? does the 318 and 325 have the same pumps? if not how much Lbs does each puts out?
                    • Brew
                      • 3060
                      Somebody should write up a injector FAQ...
                      '91 318is
                      • Fred
                        • 659
                        The fuel pumps are the same. You don't need to upgrade the pumps unless you're putting out massive amounts of power.
                        '86 325 2.8i stroker - Arctic Blue
                        '11 328i Sports Wagon - LeMans Blue
                        Strictly Eta
                        • brodee
                          • Jan 2004
                          • 2914
                          The pump puts out more pressure than the engine needs, that's why there is a pressure regulator on it. The eta engine uses a 2.5bar regulator and the b25 uses a 3.0 bar.
                          If you do the math on the stock injectors they should be good up to about 178hp at the crank. Once you get past that point the duty cycle runs too high and it's time to get something larger.
                          I put 19# injectors in mine since I have an AFPR, cam, headers, and chip. I also just picked up an m30 AFM to put on there.
                          "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                          1988 M3 - Track Rat
                          1989 325iC M50 Vert
                          1989 325i Coupe
                          1991 318is
                          1995 318ti Club Sport
                          2006 330i e90
                          2008 Tundra Crewmax
