size of drive axle nut? - need to buy socket
  • rwh11385
    lance_entities
    • 18403
    I need to Loosen the drive axle nut, but don't have a socket that fits, what size is it?
  • rs4pro3
    • 5808
    Ground down 30mm just like Tranny output flange.
    85 325e 2.7 ITB'd stroker
    • rwh11385
      lance_entities
      • 18403
      "ground down" ??
      clueless, but am brave enough to venture a guess the outside diameter needs to be filed down? to make it smaller so it can fit??? or something
      • James Crivellone
        Head Janitor
        • 6301
        Originally posted by rwh11385
        "ground down" ??
        yep
        • rwh11385
          lance_entities
          • 18403
          cool. can you explain how, and with what? thanks :D
            • 34839
            I think it depends on the socket.. the one I have didn't need ground down, fits just fine inside the hub.
              • 34839
              actually, aren't you just swapping diffs? you don't need to remove the driveshafts from the hub to do that..
              • rwh11385
                lance_entities
                • 18403
                to remove the subframe and replace all the bushings, yeah. more than just diff. :)
                • rs4pro3
                  • 5808
                  I just did the same thing, I didn't remove them. i wanted to but I stripped one of the bolts going into the diff, so I'll replace them latter. I did it on christmas day and was getting tired.
                    • 34839
                    you still don't need to remove the halfshafts.. I did the CV boots without touching the hub nuts!
                    just unbolt them from the diff, it's easy and they'll just drop down. you can also drop the whole subframe/diff/trailing arm assembly as one unit and then take it apart away from the car where it's easier.. at least that's what I did. less crawling around on the ground that way ;)
                    • rwh11385
                      lance_entities
                      • 18403
                      well I was just going off of BEN technical article. fuck yeah!
                      so I don't need the breaker bar and 30mm socket I just bought.....and tried to use? :evil: oh well.
                      • AdamF 88iS
                        • 2051
                        Yea just leave the shafts in the hubs, and remove the trailing arms with them still in there all as one piece.
                        Adam Fogg- '88 M3
                        Common sense- It's the new 'gifted'
                          • 34839
                          haha, I'm thinking of all the poor E30 owners out there who've used the same article and are removing their rear driveshafts for no reason! misinformation rules!
                          yeah, the only time you should ever have to remove the rear nuts is to change your wheel bearings. and even then, that's not something I would want to tackle on my own anyway (without the factory wheel bearing tool at least).
                          • rwh11385
                            lance_entities
                            • 18403
                            misinformation........?
                            :roll: that's surely an e30 first.......
                            • Ryan Stewart
                              I Love Miatas
                              • 8978
                              dont blame BEN, even the Bentley says to remove the driveshafts while working on the subframe. I think their intent was to protect the CVs from accidental damage.
                              I did th whole subframe without pulling those also.
                              Im now E30less.
