Stopleak
  • llll1l1ll
    • 782
    Stopleak
    Would I be able to use this through the cooling system in my 325i?
    There is a hilariously slow leak (yet annoying where I have to refill every month) coming from a gasket (that I built) on the throttle body.
    I figure if I just throw some Stopleak in the reservoir and then fill coolant on top of it, the stuff will cycle through.
    OR
    Will I have to unhook a hose to quickly dump it in? This would cause a mess since any disconnected hose = coolant everywhere.
    OR
    Is Stopleak teh bad?
    Best,
    Pete
    Me: "I can't wait to redline my car!"
    Mark: "Didn't you just break a rocker arm?"
    Me: "Yeah, I don't think I've learned my lesson."
    Mark: "You never will."
  • 3bvert
    • 1032
    a lot of peole I know use the bars leak, copper color one without problems. volvos, vw's, mb's and bmw's
    I have used in in big block chevys and fords,, a few volvos and a few british cars, adn cars and often used to seal heater core leaks.
    but not running any in my bmw right now
    however, when I bought my bmw, that at the time was known to have a bad head gasket, wehn I drained the fluid, it was way obvious thta they had put in several bottles probabally to try to seal it
    supposedly what I have been told, the copper color wone is less likely to plug any small passage and does not have a chemical reaction to the various metals in the engines
    but of course the best thing is to fix the problem right
      • 34839
      replace the 25 cent gasket on the throttle body. use new screws, which will cost you about $2, and get some new coolant, $7, with a 99 cent jug of distilled water from the grocery store. Spend $10 and fix it right instead of filling your engine with goo.
      • 416stroker
        • May 2008
        • 2448
        You can use pepper it will work great till you get a new gasket and it will smell good at first. LOL
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
          Any type of stop leak is a bad idea. While it might (temporarily) plug up the leak it will also gunk up the cooling system. If your leak is only at the throttle body, do a proper repair with the correct parts. And pressure test the cooling system to see if there are other leaks and fix as indicated.
          • jeffw
            • 1087
            fuck stop leak. fix it right so you don't have to worry about it later. its a cheap gasket and some screws
            • Jean
              • 18228
              since you know where the leak is, and it's in a relatively easy spot to fix why not fix it right?
              • Holland
                • Nov 2008
                • 7212
                I had to replace my entire cooling system (Radiator, hoses, thermostat, waterpump) because PO used too much stop leak. just don't do it.
                Originally posted by DEV0 E30
                • llll1l1ll
                  • 782
                  Welp, I guess laziness won't let me get away with this one. I guess it's also a good time to replace my throttle body gasket!
                  Anyway, thanks for the help, forum!
                  If there's one thing to be thankful for this Thanksgiving, it's this forum.
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    If you have to run it, that is the stuff to get. Interestingly, its factory fill in some older Cadillacs.
                    -Dave
                    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                    Need some help figuring out the ETM?
