engine died on the way to work
  • CobraKai
    • 1544
    so i was driving into work today, everythings fine and dandy. about a mile away from my work my engine just shut down and wouldnt fire back up. i coasted into a parking lot and tried to turn it over and it turns over it just sounds like the starter isnt catching and firing up. as many of you know my brother(tj/digitalwave) has had an e30 and an e36 for years and knows his share about it so he had me check my fuses and they're all fine.
    any ideas on what it could be? fuel pump, starter, something?
    im getting it towed back to my house later today so any ideas on anything i can do to possibly start it up and drive it home. jump it maybe?
    thanks for any advice.
    -alex
    i take pictures.
    • 34839
    are you getting spark?
    • CobraKai
      • 1544
      honestly, i dont know and dont know how to check.
      -alex
      i take pictures.
      • shiboujin
        • Feb 2006
        • 2791
        probably fuel pump. happened to me before. same exact thing.
        • barry
          • 1642
          Fuel test
          Disconnect fuel line, turn over engine to see if your pump works.
          Good luck
          Barry
            • 34839
            pull a spark plug, ground it on the engine somewhere, have somebody crank the car and see if it sparks or not.
            • CobraKai
              • 1544
              well ill let you guys know what i figure out once i get it towed back to my house. thanks for the help.
              -alex
              i take pictures.
              • metalix1021
                • Apr 2008
                • 246
                what's it sound like when it turns over? faster than normal?
                Broken timing belt?
                • CobraKai
                  • 1544
                  yeah turned out it was my timing belt :/
                  -alex
                  i take pictures.
                  • gazellebeigem3
                    • Jun 2005
                    • 3712
                    ouch!
