tricks to changing out the power steering hoses
  • ///M42 sport
    • 3952
    trying to do this right now on the 318is. there are three hoses, two of which are in really tight places. I managed to change the hose that runs from the resevoir to the pump, but cant get to the two that bolt onto the steering rack. anyone what size bolts these are?
  • rs4pro3
    • 5808
    22/19/ and 24 I believe I know the ones on the pump are 19 and 22
    85 325e 2.7 ITB'd stroker
    • christophbmw
      • Mar 2004
      • 363
      tight? i replaced all p/s hoses on my 318is and it was far from tight. remove the airbox this might help. also remove the resivor and start the banjo bolts on the steering rack, & pump before you connect the other side's of the hoses to the resivor. this will help align them, and dont overtighten the banjo bolts, dont forget the are hollow.
      '91 318is
      • ///M42 sport
        • 3952
        so you worked from the top to replace this hose?
        • christophbmw
          • Mar 2004
          • 363
          thats the hose that goes from the rack to the p/s pump right? i had my car on a lift, are you working from the top?
          '91 318is
          • ///M42 sport
            • 3952
            all I have are jackstands. so I was wondering which way is easier. I don't see how you can reach this hose from the bottom?
            • rs4pro3
              • 5808
              Under the car with a Boxwrench, there is a good size opening by the tranny.
              • DaN
                • 1265
                Don't lose the little copper washers that seal the banjo bolts, unless you have new ones handy.
                • Jordan
                  • 12913
                  Don're reuse them either.. buy new ones. They are copper crush rings, designed for single use.
                  https://mtechniqueabs.com/
                  • DaN
                    • 1265
                    well it's definitely advisible to get new ones, in a pinch they can be reused. they are solid not hollow ones that actually crush.
                    • ///M42 sport
                      • 3952
                      thanks, it was an odd angle but I was able to reach both the bolts and replace the hoses fairly easily.
                      • christophbmw
                        • Mar 2004
                        • 363
                        dude use aluminum washers, they crush easier with the banjo bolts.
                        '91 318is
