I've got a big problem. HELP!!
  • matt325is
    • 409
    Well, I'm replacing my old head bolts (with now washers), with Metric Blue's with washers. And well, I have done 2 bolts. On the third, I was torquing from 25 to 55.... and SNAP. I imediately took the bolt out, and found about .5" of thread are missing from the bottom of the bolt. I was using oil half way up the thread when torquing. Not sure what to do. I have a bolt retriever, but these suckers are deep. Any suggestions? I really dont want this to happen to anymore bolts, as I only have one extra.
    Please advise, thanks,
    matt
  • Jordan
    • 12916
    You will most likely need to pull the head off to reach the snapped off section with a extractor. Make sure you chase the threads with a tap next time. :?
    https://mtechniqueabs.com/
    • arnoldgtr
      • Mar 2004
      • 153
      ...also make sure there is no oil in the bottom of the hole.
      John
      88 ///M3 Cinnabar
      84 318i Black
      • DaN
        • 1265
        yes, there must have been alot of oil in the hole. oil doesnt compress... snap
        • trent
          Matt, I am very surprized you arn't running a Head Stud Kit.
          I really think you should be especially considering your application.
          • diegom6
            • 4447
            what happened matt at the end? did you pull off the mssing part?
            I did the same li 1.5 months ago, the same bolts, but I didn't have any problem, I only cleaned the hhole, dryed it and then I applied some thin oil in the thread and then torqed it twice, like 30 and then 60 If I remember well,
            Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
            • matt325is
              • 409
              Hey,
              I used the broken bolt to get the broken piece out, just applied pressure, and untwisted it. Worked like a champ. Then pu the rest in, and she fired right up. I'd have to say I was pretty lucky, thanks for the help guys.
              matt
