S14 timing tensioner question!
  • diegom6
    • 4447
    For what porpouse exactly is amde that litle hole or valve in the tensioner? What i must put in there and when?
    Thanks
    Diego
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • rs4pro3
    • 5808
    I believe you need to fill it with oil and bleed it, or at least on the S38's you have to.
    85 325e 2.7 ITB'd stroker
    • cramer
      • 1812
      correct.
      You can also use the E36 M3 tensioner on the S14, self adjusting and no setup.
      Chris
      90 Corrado/91 M3/01 M5
      • diegom6
        • 4447
        correct.
        yes, we installed once ae36 tensioner in a s14 with out touching it, but I just noticed it today and was bit confused about what to do with it!
        Thanks!
        • arnoldgtr
          • Mar 2004
          • 153
          It's not a bleeder, but a primer. Fill it with oil before cranking the engine. It will keep the chain from rattling on first startup.
          I used a pistol oiler and a length of clear tubing to prime the tensioner. It's the only time I didn't get the chain rattle after removing/replacing the tensioner.
          John
          88 ///M3 Cinnabar
          84 318i Black
          • diegom6
            • 4447
            Understood!
            Thanks for the input! :D
