OBC lights
  • robert325is
    • Aug 2004
    • 1171
    OBC lights
    the lights on my OBC are very faint, you can barely see them, and only when lloking at an angle. could this be a burnt out bulb or just a loose connection somewhere?
  • robert325is
    • Aug 2004
    • 1171
    BUMP^
    • Tangent
      • Mar 2004
      • 476
      This might seem like an odd question but does this only happen when it's bright out? Right now I'm using a relatively cheap pair of polarized sunglasses and I noticed that it makes the OBC look very dim. If I tilt my head and change the angle of the polarization in the sunglasses the OBC suddenly gets brighter.
      • Court M3
        • Jan 2004
        • 6713
        are the headlights on? I've noticed on both of my cars,when they are turned on, the OBC lights dim. If not it's probably because it's light out :? Not really sure
        Continuous For Sale Thread
        323i s50
        • jht3
          • 288
          obviously you don't understand polarization. put on your sunglasses and look at any LCD screen and you rotate it.
          James
          '88 M3
          • Sean
            • 5793
            Re: OBC lights
            There are two small light bulbs behind the LCD screen that could possibly be out.
            Find information, resources and relevant links for bmwe30.net. This domain may be for sale.
            Unless you had polarized sunglasses on, that's why you can barely see it. my parts car is the same way.
            - Sean Hayes
            • robert325is
              • Aug 2004
              • 1171
              it used to work fine w/ no sunglasses... then lets just say my car "went over a big bump" and then you can't see it all that great anymore.. i'll check the bulbs this weekend.. thanks for the link sean
