What useless things have you gotten rid of under the hood?
  • Denny
    • Jan 2010
    • 822
    I want to get rid of stuff that just takes room for nothing..
    EX: ABS system, etc....
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    Power steering pump, horns, charcoal cannister, all the AC parts and aux fan, fan & shroud (replaced with an SPAL), all of the sound deadening stuff, and various plastic pieces. The ABS system is well worth keeping. It is actually pretty good and can save your butt in a panic stop or in the wet.
      • 34847
      clutch fan, stock coil, cap/rotor, a/c, windshield washers
      my ABS actually saved my ass yesterday.. a light turned yellow so I stopped. it was pretty wet and the traction on the left and right sides of the car was not even (one side was asphalt, the other side tar). the car pitched left about 15 degrees, then ABS came on and straigthened me out.
      I probably could have just blew the light but part of me just wanted to see how well I could stop in the wet. No amount of threshold braking would help in that situation, since you can't change how the left and right sides of the car brake manually.
      there wasn't anything for me to hit (middle of nowhere) so I probably would have just spun, but I really didn't want to find out. :)
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        engine. Really.
        • SA E30
          • 1248
          Washer bottle, Air con, ABS, Power Steering, Fuse Box, brake booster... Pretty much only useful thing in the engine bay is the engine.
          P.S. Fuses located inside cabin now.
          • Aptyp
            • 6584
            windshield washer is all I've taken out for good.
            • ZM Blue Devil
              • Dec 2006
              • 13836
              Put in m42 radiator to get rid of overflow tank.
              Levent
              %20levent@gutenparts.com
              Ladies:
              • Denny
                • Jan 2010
                • 822
                Thats awesome...is it a direct replacement or do you have to do modifications?
                Denny
                ___________
                Blogs:
                • ZM Blue Devil
                  • Dec 2006
                  • 13836
                  ^minor mods.
                  Levent
                  Ladies:
                  • Denny
                    • Jan 2010
                    • 822
                    I guess I will keep the ABS as everybody seems to say.
                    How much work was involved in relocating the fuse box? It does take a lot of room.
                    One thing I wanted to know....my 1987 325IS has the battery in the engine bay...(I heard only the tourings had them in the engine bay)
                    Denny
                    ___________
                    Blogs:
                    • Denny
                      • Jan 2010
                      • 822
                      ^minor mods.
                      Did you use the stock cooling system hoses?
                      Denny
                      ___________
                      Blogs:
                      • Farbin Kaiber
                        Lil' Puppet
                        • 29502
                        There are some oddball cars with the battery in the front.
                        • Denny
                          • Jan 2010
                          • 822
                          how about converting the big ass Radiator fan to a slim electric one?
                          Denny
                          ___________
                          Blogs:
                          • HarryPotter
                            • Jan 2010
                            • 3642
                            Pretty sure all cabbies have them up front. Along with some across the pond 318's.
                            John F. Kennedy
                            • dashboardmonkey
                              FUCK YOUR WAFFLES
                              • Jun 2008
                              • 6158
                              throttle body heater
                              -Andy
