Found a 325e for $600
  • TimmyBigHands
    • 260
    And just finished writing the check to buy it.
    It's an 86 - so it's quite hideous with diving boards and whatnot.... but it's a 2 door and has the 2.7 ETA in it. I can use some parts off it to complete a 2.7i motor, the dashboard, etc...
    Currently, I have the 90 2.5i sedan. I'm wondering, can I just simply swap my head/intake onto the E block and go, or will the pistons hit the valves? Do ya'll think I should swap my head to the E car, or pull the E block and mine and then swap the completed motor into my sedan?
    Are there any writeups on how to swap the plastic bumpers onto the older car? I realise this is kinda open-ended, but LMK what you guys would do with a spare car and the desire to have a 2.7i (cheap).
  • Jordan
    • 12911
    Duh.
    https://mtechniqueabs.com/
    • Sean
      • 5793
      You'll need Super Eta pistons or custom made pistons.
      Regarding the engine questioin - like, which car to end up using - whatever one has a better exterior.
      The engine is a lot easier to swap then it is to pay for a respray, quite personally. I'd put the completed stroker in your sedan.
      - Sean Hayes
      • James Crivellone
        Head Janitor
        • 6301
        No you won't, you will just get a rather low compression ratio not fit for an N/A motor
        • TimmyBigHands
          • 260
          after some investigating, it looks like I'll end up with 7.9:1 CR. Perfect for big boost. I may go with that and deal with the poopy lag till I can afford the turbo setup.
          Any idea on HOW poopy this will feel?
