M20 runs horribly. i need all the help i can get.
  • Special_K
    • Dec 2008
    • 19
    Symptoms:
    ~Misfire becomes very prominent when under load.
    ~No power
    ~Barely idles
    ~Stomp test doesn't work...
    ~When given throttle input (in neutral), the revs initially go up, but after a second or two drop back down to idle even if the throttle does not move. This occurs when the throttle input is under 50%.
    ~Unplugging the IAC doesn't change how the engine runs (when ignition is in run mode, it can be heard buzzing along with the computer)
    ~The turn signal fuse (15amp) blows often. not all the time, but often. I know that's associated somehow with the stomp test.
    ~Fuel pump is a little noisy, but the line is definitely pressurized.
    What i know:
    ~the injectors work, click, shoot fuel etc.
    ~there is spark. all spark plug wires are fine
    ~vacuum leaks are very minimal
    Notes:
    ~I just rebuilt the engine (no head work or bottom end work), new timing belt, water pump, head gasket, etc.
    ~I have two DME's. symptoms are the same for both.
    thats all i can think of for now. any ideas you have. ANY. post em up.
  • Wh33lhop
    • 11705
    Sounds like something important is very wrong. Did you triple-check your plug wires' order? Confirm the timing is correct at TDC? Is it running rough, like it's only running on a few cylinders?
    paint sucks
      The first actions should be to have a smoke test run on the intake and fix the leaks that are found, run the fuel system test suite in the Bentley manual, and double check cam timing.
      • Special_K
        • Dec 2008
        • 19
        how to run smoke test myself?
        • ZombiE30
          • Dec 2009
          • 438
          ....also ohm out your AFM or swap in a known working one. Or unplug it and see if that changes anything (it should run noticably worse when unplugged).
          If that's gone out, your car will run like complete ass (much as you described).
          Originally posted by stoliver54
          Aw, balls.
          FS: assault gear....
          http://www.r3vlimited.com/board/showthread.php?t=159253
            If you don't have a smoke machine you can't run the test yourself. Since entry price for a smoke machine is in excess of $700, you probably won't find one outside of a well equipped shop.
            The cost to run a smoke test is generally no more than one hour of shop time, so it isn't a terribly expensive test.
            • 10yre30r
              • Jan 2010
              • 97
              Make sure you put the timing on TDC. The crank..lined up and the cam sprocket lined up correctly . What you describe sounds alot like youve got your spark plug wires in wrong order.
              • Vtec?lol
                • Dec 2009
                • 3278
                You should check the fuel pressure when the engine is under load or throttled up.
                Seems like you've left a hose lose. Or a lose connection. Those fuel injection wires seem to break easily. Check them by the connector.
                • Special_K
                  • Dec 2008
                  • 19
                  Ok afm is fine.
                  spark plug wires are correct and working.
                  injector wires all work because i can get them to click from the dme harness
                  im going to have to check to make sure timing is correct and fuel pressure is good.
                  • StereoInstaller1
                    GAS
                    • 22679
                    I would do a compression test first.
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • Special_K
                      • Dec 2008
                      • 19
                      Unfortunately, i dont have a compression tester immediately available.
                      • 330SMG
                        • Feb 2007
                        • 172
                        What does the oil and antifreeze look like, does it smoke?
                        Or it is either fuel or a massive vacuum leak. to check for a leak spray wd-40 around the intake manifold connections especially where it mates to the head.
                        What do the plugs look like are they black(rich) or white(lean)? A fuel problem would lead to white plugs.
                        1989 Cirrus Blau coupe Racing Dynamics wheels and a Volvo Spoiler.
                        • hotballs
                          • 1155
                          Yeah crazy vacuum leak or bad sensor. Coolant temp sensor can throw things off. CPS sensor could be bad. Check the three relays under the hood. Swap those out with a couple different ones. Swap a known working computer. I don't know if the TPS would cause all this, but you could check that after everything everyone else said and the sensors, relays, ecu...etc.
                          • StereoInstaller1
                            GAS
                            • 22679
                            or it could be as easy as CPS switched with CRS...but that does not sound like the symptoms.
                            Closing SOON!
                            • StereoInstaller1
                              GAS
                              • 22679
                              Oh yeah, a compression tester is like $20 and should be in everyones tool kit
                              Closing SOON!
