Need help adjusting throtte stop screw
  • the bob
    • Aug 2004
    • 51
    I know that I should have left it alone.
    I am not a mechanic and mess with stuff that gets me in trouble but that is why I drive old cheap cars so that when I screw them up it is not a huge financial burden as much as an exercise in my ability to brake stuff. So please dont remind me. I already know.
    That being said
    I could use a little guidance on setting the stop on the throttle. I adjusted it because of a thread I read on the web about adjusting your throttle position sensor.
    I figure that if I can get it in the ballpark that the computer will manage it from there. The problem is where is the ball park.
    I am assuming that with the tps wires pulled that the idle should somewhere between normal and 3000 ( it was at 3000 before I adjusted the screw) what is normal if anyone knows. I figure that if the throttle stop is oper too much that the icv will not have any room to control air flow. Currently at the setting when I remove the wires connection from the icv there is no change in the idle characteristics.
    btw 87 325i
    I am waiting on a new (slightly used afm from ebay) So I am going to hold off on messing with it too much until I get that part.
    Would this stuff cause it to run rich. I am thinking that it wouldnt because it is all metered air so the computer knows about it. I just put in a oem o2 sensor. I bought the afm with the premise that it could cause rich running and after 187K could be a ware issue.
    Thanks guys and gals
    My wife begs me to buy a new car under warranty.
    but I love the way this llitte car drives.
    thanks for all your help
    i do enjoy this forum
    bob
  • Jordan
    • 12916
    Adjust the TPS, not that screw. That screw is a stopper, not an adjustment.
    https://mtechniqueabs.com/
    • the bob
      • Aug 2004
      • 51
      Yes you are right but a little late because I already messed with it.
      I am thinking of readjusting the TPS with the as it seems to be engaged at a little long off of idle. is there a spec for the clearance of the set screw while I have it off.
      OR did I screw it so bad that I have to pull one off another 325i (throttle body)
      Isn't it fun.
      It is a good thing that I have 2 cars to drive.
      thanks
      bob
      • the bob
        • Aug 2004
        • 51
        Hello all,
        this is the thread that I got the info on how and why to adjust that stop screw.
        Is it bogus.
        thanks again
        bob
        Find information, resources and relevant links for bmwe30.net. This domain may be for sale.
        • 92 mtechnic cabrio
          • 4907
          If it's from BMWE30.NET I trust it. BEN has been around for a very long time.
          Welcoem to the forums, by the way!
          R.I.P 07/01/09 - 04/23/10 :(
          • 325beast
            • May 2004
            • 20
            If you adjusted the throttle plate stop screw, you need to set it back to spec using a feeler gauge.
            The article you linked was for messing with the TPS, which is under the throttle body.
            Note that the TPS can become contaminated w/ oil and lose its ability to engage the idle system.
            Rarely will the TPS come out of adjustment.
