Strange Issue with Brakes
  • dr.gonzo
    • Nov 2009
    • 206
    Hey everyone, I finally got around to doing the H&R Cabby springs with billy sports, AKG Rear shock mounts, and m3 CAB (AKG 75D of course) car drives great (other than alignment) but when i changed the brake fluid (dot 4 of course) i now have the ABS light as well as the brake fluid light (even though I am topping it off) Could anyone shed some light
    www.roadreview.net
    • 34844
    did you forget to plug in a sensor or two?
    • Mike325
      • Mar 2006
      • 3685
      Tell us how you bled it. You could have air in the abs system.
      Originally posted by Kershaw
      • dr.gonzo
        • Nov 2009
        • 206
        My buddy pressed on the brakes while i opened the valve, I shut it before he released the brakes, they were bled until it was only clean fluid. I still have the strange low brake fluid light though
        www.roadreview.net
          Improper bleeding won't result in the ABS and BRAKE lights being on. Given the recent work, the former will be most likely to be as a result of one of the speed sensors being disconnected or otherwise an open circuit. The latter light will be due to brake fluid level sensor.
          • Hallen
            • 1008
            There is also a solenoid up under the dash that controls the ABS operation. If it is fried, the ABS won't work and the light will be on. That solenoid could have blown, but I would check what jlevie says first.
            1987 E30 325is
            1999 E46 323i
            RIP 1994 E32 740iL
            oo=[][]=oo
