Rust removal - any DIYs?
  • Fusion
    • Nov 2009
    • 3658
    I was wondering if anyone has any comprehensive rust removal DIYs, the example can be any car. My car is pretty rust free, but there's a rusted hole in the rear valence and some cancer right above the muffler.
    I pretty much know I'm going to have to strip the paint, cut out some of it, weld in a patch, bondo, paint etc. but I would rather read some info on what kind of base paint should be used or how to prevent future rust in the same spot.
    Thanks.
  • IronmanE30
    • Sep 2009
    • 2121
    Check out Eastwood they have a good product and some helpful information on DIY rust removal and preparation for finish coat.
    http://www.eastwood.com/tech-library
    Cheers,
    Jim
      Base coat over bare metal should be a self-etching primer followed in this case by an epoxy primer. In areas where moisture is a factor, a metal filled filler is preferred over ordinary bondo. When the repair is complete, undercoat the back side.
      • Fusion
        • Nov 2009
        • 3658
        Thanks guys!
