I have a short shifter on my g260 with bronze bushings, and its short as hell. It was all fine until yesterday when i shifted into 3rd and the shifter popped up. It still shifts fine, but it has an inch or two of vertical play. It was put in when i finished my swap last month. What the hell happened?
shifter issues
Tags: None
If it's using the early model shift plate type deal one of the bushings on the plate might have broke causing the vertical play. Take the boot off and check it out.
John F. Kennedy
The rear mount is loose. It's about 6" behind the shifter in the trans tunnel.'89 325i track sloot
'01 530i daily
-EnginerdComment
Perhaps the Nylon shifter cup the shifter sits in wasn't fully snapped in. (if you are using the nylon cup) There are two ears that fit into two corresponding slots that lock it in place. If they wern't locked in, the shifter would move upward.
If that's the case, you can probably pull the leather and rubber boots up and get the shifter and cup back in-place from the interior.
Good luck!
1999 540it - Jet Black/Sand Beige
1998 318ti - Schwartz/Anthraz
1997 318ti - Schwartz/Anthraz
1995 318ti - Alpineweib/Schwartz
1994 325i - Bostongrau/Sand
1991 318ic - Schwarz/Anthratz Stoff
BMWCCA# 160411Comment
yup, check the rear rubber mount, its probably either in 2 peices(cheap to replace) or its worn enough that it poped out of its hole in the plateComment
