Tach problem?
  • ak-
    • 12422
    Tach problem?
    On the freeways of California I will once in a blue moon hit around 100mph and coast it back to the normal driving speed.
    This time however a truck next to me started toying with me and we both pulled from 80 to 100mph and from there or so I pulled a couple car lenghts ahead more from power I guess..
    Now, I only mention this because I'm using the truck as a point of reference.
    When I looked down at my tach, I noticed my needle didn't go past the 100mph mark although I know for a fact my car did indeed go past 100mph because I pulled on him at that speed..
    Anyone here or experience this?
    I have a TMS chip installed by the way if that helps.
    325is / 4.10 lsd / revving passed 4krpm is all I remember.
    195/65/14 on weaves.
    Thank you!
    tl;dr = Tach needle wont go over 100mph, I have a TMS chip if that helps.
    1991 325iS turbo
    What the tach should read is a function of what gear you were in. At a true speed of 100mph on standard sized tires a manual transmission 325i with a 3.73 diff would have the displaying 5500rpm in 4th or 4500rpm in 5th.
    Be aware that the speedometer on a BMW almost always reads high and some read high by quite a bit.
    • Wh33lhop
      • 11705
      If your tach is reading 100mph, your car just broke the laws of physics.
      Also, I think you trippin' dawg.
      paint sucks
      • ak-
        • 12422
        I was creeping up past 90mph at a good pace and using the truck as a point of reference, I know I went passed 100 when I was crawling away from him.
        1991 325iS turbo
        • kylekrueger
          • Oct 2009
          • 250
          do you mean speedometer??:???:
          • ak-
            • 12422
            Sure.
            1991 325iS turbo
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              I'm confused.
              Put the bong down and post up later
              -Andy
              • ak-
                • 12422
                Rite...
                1991 325iS turbo
                • e30trooper
                  • 11576
                  I can do 100 in 4th at around 4500 rpms :D thanks to my s2.93
                  • ak-
                    • 12422
                    Lol, can anyone help me out?
                    1991 325iS turbo
                    • ADEN
                      • 620
                      may be the problem is in you gauge gears. i guess
                      • bddog
                        • 351
                        On average , at 67mph, your speedo will be off by 5 , to the positive. Tested a few.- Steve
