Alternator wiring modification.
  • Jordan
    • 12916
    I was just looking at some old pictures of the engine I took out of my parts car and couldn't help but notice how small the wires for the alternator are!.
    The + looks like 8-6ga, and the - looks like 12-10ga. Seems to be overly small, especially considering its low strand count crappy wire. Considering that at any time up to 90+ amps are trying to flow through that wire..... bigger could make a noticable difference.
    Has anyone ever replaced it with like a 4ga + and 8ga - (car stereo wiring) leads before?
    I'm pretty sure the + lead just runs through the main engine harness, and terminates at the junction block above the battery tray, but I'm not sure where the - lead terminates. Anyone know?
    https://mtechniqueabs.com/
  • rs4pro3
    • 5808
    the Main Red wire goes threw the harness then the other end attaches to the 13mm post on the starter.
    85 325e 2.7 ITB'd stroker
    • Jordan
      • 12916
      Oh awesome. Thats a nice short run. I definately have enough 4ga red power wire to make that run.
      any idea where the negative lead goes?
      • Brew
        • 3060
        Couldn't you just run a 4 ga right to the frame rail? I think there is a ground strap there already.
        '91 318is
        • Jordan
          • 12916
          If the lead just terminates to the body somewhere else, yes I could. But I need to make sure that is the case first.
          I could go outside, pop my hood, poke around and try to see... but its cold and dark.
          • Brew
            • 3060
            Well, it is a ground, so it has to terminate at the body or at the negative terminal of the battery at some point.
            '91 318is
            • Jordan
              • 12916
              It looks like it may also terminate at the starter motor. Can you confirm Ely?
              • Skafrog
                • 1732
                it depends on the starter you have. Is it a big case or a small case? (2 or three wires coming from the starter?)
                NASA MidSouth TT Director / GTS2 #018
                Mods: Coastal PS Fluid, 10w40 Oil
                Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                • Jordan
                  • 12916
                  This is the starter/wiring configuration I used in my car (prior to being cleaned up)
                  • rs4pro3
                    • 5808
                    the smaller bundle of wires goes to the instrument cluster for the Battery light. The ground for the alternator is threw it's case or some have an external 3" wire that grounds to the engine block.
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      Most alternator grounds ground at the engine block, and the chassis. I think the alternator on mine grounds to the chassis just inside the d/s front wheel.
                      Will
                      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                      Welcome e30 (brilliantrot '90 325is) 12/23/06
                      DaveCN = Old Man
                      My signature picture was taken by ME! Not by anyone else!
                      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                      • Hubbert
                        • Oct 2004
                        • 67
                        Having a charging problem? or just wan't to make sure 100% output ? what battery are
                        you using ? Lights dimming? I bet they do if you run full lights and system cranked !
                        A cap and or Optima battery would help. When ya get a chance , I still would like to know how you run full lights, or fogs only on are cars, 06/87 build date. thanks Jordan ...
                        John Hubbert
                        • parkerbink
                          • Jun 2004
                          • 10138
                          I have been thinking about doing this for a while. I got great info here:
                          Thanks for starting this thread Jordan!
                          • Jordan
                            • 12916
                            No charging problem, just want to make sure everything is 100%
                            what battery are you using ?
                            Factory spec Exide battery (huge one)
                            Nope. I can have the system at max, all 6 lights on, car at idle. No dim.
                            Sorry man, I forgot about that. I will PM you soon with the info.
                            • AdamF 88iS
                              • 2051
                              It's not a - or ground wire. It's a field wire and it also triggers the warning light in the dash. Don't mess with it, it doesn't carry much current.
                              Adam Fogg- '88 M3
                              Common sense- It's the new 'gifted'
