Ok, so I started my car up on morning Friday, and it sat and idled at 1200rpm, damn high it normally idle's at 750rpm. when I strted it on friday night when I was leaving my mates house, it was idling at around 400rpm, and once again this morning. I'm almost sure it must be the AFM, but I thought I would ask and see if it could be something else ?
325i Idling Issues
O2 sensors dont do much on E30s anyway. You can drive around with it unplugged all day and never notice a difference, unless your car has a check engine light of course. It only helps make really fine adjustments to the mixture. Furthermore, the idle on our cars is open loop, this means that most sensor inputs, including O2, are ignored when that idle swtich is on.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
