Rough Idle, Black Smoke.
  • BMW BMXER
    • 2325
    Symptoms:
    -Bumpy idle, sorta of sputtery puttering and shuddering
    -Idle goes up and down
    -Slight Black smoke on idle (will check to see if during accel too just need my dad to hold the gas)
    -ICV screw all the way out idle doesnt go up and down but it idles like shit
    -ICV screw midway to down idle goes up and down to almost the point of stalling, never really settles.
    Possible Related issues:
    -Sudden temp change
    -Exhaust leak right after the manifold and before the muffler
    -325 ish thousand miles
    Possible fixes I have thought of
    -Hit ICV with hammer
    -Hit ICV with bigger hammer
    -Shoot ICV
    -Buy new one
    -Your suggestions?
    Sold it.
  • EtaSport
    • 2853
    Hard to say. Mine did the same thing and wasnt related to the icv in any way. All I know is that its either getting a WOT signal and dumping fuel in that it can't burn, or its getting the right signal but not getting a strong enough spark to burn it off. I replaced my coil, wires, and distributor cap and my problem went away. Other things to check:
    TPS, and setting
    AFM
    maybe swap ICV
    Fuel filter
    Fuel pump
    Cold start injector
    Coolant sensors
    Fuel injectors
    ECU
    ICM
    unfortunately, and im sure you know, these things dont tell you too much. It seems like all m20 problems have identical symptoms and completely different remedies. I would still look into the ignition however. Check to see if you have a strong/regular spark on your plugs. They are probably carbon fouled as well, so I'd buy some new ones and check the new one. Good luck, hope some of this helps.
    Old and improved:
      • 34839
      not a solution, but a clue. black smoke usually indicates a rich condition. you should be able to smell it out of the exhaust.. if you don't know what a rich mixture smells like, go stand behind a carb'd chevy and you'll know really quick. :)
      read your plugs too, it's easy and you'll be able to confirm the above.
      and make sure you test the TPS. my car has an exhaust leak right after the manifolds as well (there's a crack) but that shouldn't affect your idle since the O2 sensor is ignored when you're idling.
      • BMW BMXER
        • 2325
        The plugs are about 6 months old.
        Fuel Filter is about 6 months old.
        I cleaned the icv with some shit called xlylene that my dad said "should so the trick" the idle isn't lumpy anymore but still loopy. No more smoke.
        Car does run rich though.
        How do I check the tps?
        Sold it.
        • EtaSport
          • 2853
          When you open the throttle plate on the throttle body you should hear a click when the butterfly is open. If you do not hear the click then you need to loosen the screws on the TPS and turn it until you can hear the click. I think it only has two signals, closed for idle, and open for WOT. Other than that, id just say clean everything, maybe try some fuel injector cleaner, or fuel treatment, and again check for any leaks.
          Old and improved:
          • BMW BMXER
            • 2325
            Thanks I will check that out.
            How does an ICV work exactly? I know there seems to be a motor or something that spins around in it that does... something. But I don't know what?
            Can anyone shed some light on the subject?
            Sold it.
            • DaN
              • 1265
              Have you checked the fuel pressure regulator?, Whats your fuel pressure?
              • EtaSport
                • 2853
                oh yea, forgot about that, shame on me.
                pretaining to the ICV~Not sure how the thing works. I read somewhere that there was even an electric wire inside of it (or similiar) that reads changes in air flow and sends signals. The way I read it, it works much like a mas air flow meter. The rest I know is that it lets unmetered air into the intake, and how much is controled by the screw. Someone is bound to know. Im curious myself.
                Old and improved:
                • DaN
                  • 1265
                  Whatt???
                  The fuel pressure regulator is mounted on the end of the fuel rail, it regulates the pressure in the rail. If its stuck closed then pressure will be to high, each time the injectors open too much fuel will be injected.
                  You are refering to the air flow meter, all the air that goes into the engine is routed through this device which has a door that changes position with flow.Mounted on the door is a potentiometer, resistance varies with flow. The computer takes this info and makes calculations for injector pulse width, ignition timing, etc.
                  • EtaSport
                    • 2853
                    Oh, I wasnt talking about the fuel pressure regulator, I was trying to answer his question about the ICV
                    Old and improved:
                    • kowalski
                      • Jan 2005
                      • 1791
                      by reading the plugs he meant
                      black is rich
                      brown is normal
                      grey is lean
                      • rwh11385
                        lance_entities
                        • 18403
                        update?
                        • BMW BMXER
                          • 2325
                          Oh right, I fixed my exhaust, cleaned my plugs, replaced my air filiter with a K&N, cleaned and adjusted my ICV multiple times, got a chip and started running better gas and the weather got a lot better.
                          Any combination of these has since fixed my problem.
                          Sold it.
                          • arnoldgtr
                            • Mar 2004
                            • 153
                            The ICV regulates the amount of air that bypasses the throttle. More air means a higher idle speed.
                            The ICV is a solenoid, or linear motor. It has a coil of wire which creates a magnetic field, moving the plunger.
                            The early 2-wire VDO ICV's are single pole. They have a spring which holds the plunger open. When current is applied to the terminals, the ICV closes.
                            The later Bosch 3-wire ICV's are two-pole. There are two coils of wire. The normal position is half-open. Current applied to one coil will open it further. Current applied to the other coil will close it fully.
                            The later design is superior because if it fails electrically it is in a fairly 'normal' idle position. With the early VDO ICV, electrical failure means the ICV will be wide open, causing the 2000+ RPM idle situation.
                            The two ICV designs are not compatable. The VDO ICV is controlled by a separate control unit. The Bosch ICV is controlled by the Motronic unit (ECU).
                            John
                            88 ///M3 Cinnabar
                            84 318i Black
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              It's actually "xylene". I hope you wore gloves and didn't breathe the fumes. It's what the English call a "carcinogen." (Just as nearly all benzene derivatives are).
                              But anyhoo... glad you got your prob fixed. What do you think it was that fixed it?
                              My idle isn't really all that stable... but I've yet to encounter an M10 with a perfect idle...
                              Originally posted by Gruelius
