HELP! Starter is posessed!
  • tryp2nite
    • Jan 2004
    • 58
    Hi guys,
    I just installed a new starter which worked totally fine for the first couple starts.
    Now when I try starting it the starter just keeps spinning even when the key is not in! I had to run and disconnect my battery!
    Can anyone PLEASE help me with this?
  • DaN
    • 1265
    Take a look at the wires going to the starter, and make sure none of them are touching eachother.
    • Jordan
      • 12913
      ROFL. That is seriously funny.
      here is a proper starting wiring configuration.
      https://mtechniqueabs.com/
      • tryp2nite
        • Jan 2004
        • 58
        That's weird... because I have one more smaller wire and terminal post than the starter in that picture.
        I have a '90 325is btw.
        • tryp2nite
          • Jan 2004
          • 58
          Checked the wiring... none are touching each other..
          • Jordan
            • 12913
            there were several different starters. That was just 1.
            • Jordan
              • 12913
              Either way sounds like your solidnoid is sticking. Whack it with the handle of a hammer until it cuts the shit.
              Solinoid is the smaller cylinder.
              • tryp2nite
                • Jan 2004
                • 58
                You were right dude... I did exactly that and now the starter behaves normally!
                Thanks guys!
                • DaN
                  • 1265
                  This is a new starter? Not a good sign, lol
                  • Jand3rson
                    • 37587
                    The starter wasn't the problem.
                    • Jordan
                      • 12913
                      NP dude, happy to help.
                      This falls under the "shit happens" catagory. New starter or not the solinoid can still get caught on a sliver of the flywheel and not be able to disengage.
                      Just as an FYI your starter wasn't actually running, the clutch inside of it was just whining because it was being driven by the flywheel. Although this doesn't *really* hurt the starter in our cars I still would not recommend making this a daily routine.
                      • DaN
                        • 1265
                        The solenoid comes with the starter.
                        New solenoid.
