First off, if anyone knows of a FAQ or guide that would be great. It seems fairly strightforward but I have a few questions:
1.) Does the late model use a different water pump? The timing belt/water pump was replaced about a year ago so I don't see it necessary to do all that again (but will if necessary) (and my cars production date: 10/87 but it an 88)
2.) Does the radiator swap easily?
3.) What do I use to mount the expansion tank?
Other than that I guess it seems pretty simple...just drain the coolant, swap everything, refill it with coolant, then maybe bleed it?
