Damn slave cylinder
  • cahomey
    • Mar 2004
    • 1201
    Damn slave cylinder
    Ok I just replaced my slave. The new one is now in.
    Here is my problem.
    When I swapped out the old one and put in the new one, it left me with absolutly no resistance in the pedal, an empty line, and a headache.
    Now I am wondering how I go about filling the slave with fluid again? I was thinking of pressurizing the system but I don't know where to find a resivor cap with a pump attached or whatever.
    I'm sure people have done this time and time again. Share your wisdom please.
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
  • the bob
    • Aug 2004
    • 51
    congrads on getting it in.
    DId you try bleeding it yet.
    you can gravity bleed it fairly well by cracking open the bleed screw and letting it bleed out .
    you may not have the brake line fittings sitting correctly which will cause it to piss brake fluid everywhere.
    Fill up the brake fluid resevoir and gravity bleed it. then close the bleed screw
    put some fresh cardboard under there and pump the pedal back and forth. If you are leaking brake fluid then you are leaking it out somewhere.(brake line connections)
    I did not think that the slave was so hard to bleed when I did mine
    good luck
    bob
    • cahomey
      • Mar 2004
      • 1201
      So I should just open the resevoir cap and open the bleeder screw and the line should fill just by gravity?
      I'll try that tomorrow morning. Got to go to work.
      Thanks.
        • 34844
        haha, you'll never get it to bleed properly that way.. a pressure bleeder is the best way by far, but you can also try the old pumping the pedal method... have fun with that.
        • cahomey
          • Mar 2004
          • 1201
          The pumping the pedal method is out of the question.
          There is nothing to pump.
          • DaN
            • 1265
            So you filled the reservoir, opened the bleeder, and waited for the fluid to run out?
            After that close it, and you may need to pick up the pedal off the floor a few times. If you still have nothing, the rod may be broken in the master cylinder, or its just plain bad.
            • blunttech
              • 12850
              take the slave off and bleed it by hand. once in a while thats all that will do it. i have a pressure bleeder and once in a while air gets trapped and you cant get it out without removal.
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • AdamF 88iS
                • 2051
                That would be because theres no fluid in there yet. Open the bleeder and pump the pedal. When it lays on the floor get off you ass and pick it up by hand and keep going.
                Adam Fogg- '88 M3
                Common sense- It's the new 'gifted'
                • Jordan
                  • 12916
                  Seriously man....
                  https://mtechniqueabs.com/
                  • cahomey
                    • Mar 2004
                    • 1201
                    Trust. I pumped, and pumped, and pumped some more.
                    Yet nothing. Even when my friend was pumping while I opened and closed the valve.
                    I'll pump the shit out of it tomorrow and see what happends.
                    • DaN
                      • 1265
                      But did you gravity bleed it first? OR not?
                      • the bob
                        • Aug 2004
                        • 51
                        I second the premise that it coulc be a bad master cylinder.
                        good luck
