I just got finished wiring the battery to the trunk. I put the key in the ignition, turned it once, and all of the dash lights turned on. I turned the key again and everything went dead. I am not sure how to check everything but I will tell you what I did.
I put the volt meter on the battery, and it read 12 volts.
I went up under the hood and put the positive lead from the multimeter on the connector and the junction box and the negative a ground. I was reading 0 volts.
Is it a simple wiring problem? Can you lead me to what I should check?
TIA
Aaron
TIA
Aaron
