Anyone know approx CFM required to keep the e30 at proper running temp? I'm sure its different per motor, but any help is appreciated.
e-fan CFM?
pusher - 2000cfm
puller - 1600cfm
they're really only needed when idling in traffic, it will probably never come on with the car moving at any decent speed. -
pusher or puller?
hottest day I've ran was about 101f, with a 16" 2100cfm pusher. Cooling the engine was never an issue, however people's jacks and tools sinking into the expensive asphalt skid pad because it got so hot was..Comment
Mine came on for the first time ever today...sittin in a harbor freight parking lot.
Ive got a Flexalite 16in with curved blades set up as a pusher..it sits less than an inch from the front of the RAd on some brackets I made.
When it spooled up it dripped the needle immeadiatley, M42 RAD btw88 325ic ~~~> Rusty and ugly
85 E ~~~> RIPComment
the aux fan is extremely loud and draws a lot of power. I'd look for a bigger puller fan if you want some margin of safety. If you have no A/C, I'd remove the stock aux fan altogether and use the wiring harness and relays to drive your new fan, with the lower temp thermoswitch from an E36 M42 car.Comment
just a ballpark based on my experience; the pullers can be lower CFM because they're more efficient, and 2000cfm pushers seem to work fine with the AC condenser removed.Comment
well I can get a SCREAMING deal on a 16" fan but it only does 1500cfm. I was thinking about putting a kit together for everyone to replace the clutch fans with something that wasn't pulled from a junk yard for a reasonable price. It just appears it may be a tad on the low side for those who may really sit in hot situations...the aux fan is extremely loud and draws a lot of power. I'd look for a bigger puller fan if you want some margin of safety. If you have no A/C, I'd remove the stock aux fan altogether and use the wiring harness and relays to drive your new fan, with the lower temp thermoswitch from an E36 M42 car.Comment
