318is Fog lamp question...
  • bmwm3n528
    • 3654
    Are 318is without fogs, wired for fogs?
    Have found where they'll wire up at the valence, just cant find where to hook the switch up to for the button inside the car.
    Any help is appreciated, thanks.
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
  • Mike 91 318ic
    • Jun 2004
    • 429
    yes the car is wired, you'll need to dig out the wires from under the steering wheel behind the knee bolster... On my car they were on the left side below the abs module. iirc the power wire was grey and I had to make my own ground cause the PO made a mess under there which was a pita to straighten out.
    M
    • bmwm3n528
      • 3654
      M
      Well, I found the wires that are connected to the switch thing, and got the switch on....what else is there to it, other than hooking the fogs up?
      Trevor Ely
        • 34844
        relays?
        • bmwm3n528
          • 3654
          Originally posted by nando
          relays?
          Well, that's what I originally thought...but the relays are 29,30 and they're both filled on the 318.
          Guess i'll find out when I hit the switch.
          Trevor Ely
          • Mike 91 318ic
            • Jun 2004
            • 429
            I forgot you need a k8 relay.
            M
