Tuning question
    Tuning question
    If i were to put new cams and bigger injectors in the m50 would i need a programmable chip or standalone to run it? Or can you tune the stock motronic system? I know nothing about tuning so go easy.
    86 Zinno es
    M50 inside
    get a chip made for the hardware you use
    Like ActiveAuto, or find "Matt" here on the r3v
    1989 cirrisblau-metallic 325i
      But then id have to change that when i went turbo or made more upgrades right?
      86 Zinno es
      M50 inside
        Right
          Miller WAR chip.
          /thread
          Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
            If only i had money. Fuckin tunings foiling all my plans for moar powar when im jobless.
            86 Zinno es
            M50 inside
              it depends how aggressive the change is. if the injectors are only a few CCs off you could get away with it without washing your cyl walls with fuel.
              if the cams are going to be super lopey, i don't think so.
              You'll get more power if you tune it anyway.
                I know ill get more power, and im doing it eventually either way i just wanted to know if i could get away with it for now. The cams arent too aggressive, im having them reground to m3 specs and the injectors are probably gonna be no more than a few cc's larger.
                86 Zinno es
                M50 inside
