redline 75w 90 or shockproof???
    I was wondering what yall suggest?? I have heard shockproof locks up harder and faster. We are talking about final drive gear oil btw.
    Unless you're talking a fresh, rebuilt diff, I wouldn't run shockproof in a 150k+ mile rear end.
    -Charlie
    Swing wild, brake later, don't apologize.
    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
    FYYFF
      even in freshly rebuilt diffs, diffsonline suggests redline 75w90 with an lsd additive. we've had the best results with it.
      Dan
        Why would you add a LS additive to the regular 75w90? The NS varient, maybe.
        -Charlie
        FYYFF
          yea, i just meant to make sure it has lsd additive in it, not to add more
          Dan
            [threadjack]
            How would shockproof work in a noisy 235k gearbox? Would it quiet it signficantly, when compared to synthetic 75w-140?
              Originally posted by DaN
              [threadjack]
              It would hasten putting it out of its misery.
              -Charlie
              FYYFF
                So you're saying it would wear it out sooner? Why?
                  You guys should be running a non-detergent 50W. I have found that works best. :up:
                    Shock proof is very light, it's intended for qualifying laps and drag racing, not normal street or race usage. It certainly wouldn't quiet a diff, and I'm sure wouldn't be good for a higher mileage unit.
                    -Charlie
                    FYYFF
                      so basically return the shockproof?
                        ya, get redline... unless you hate your diff.
                          I personally would not run it in an older diff, but have not actually tried it. YMMV. I would actually love to see a dyno pull between "conventional" fluid and the shockproof in an e30 diff.
                          -Charlie
                          FYYFF
                            don't mean to question your knowledge, but the redline website makes it sound like it is a very high viscocity fluid that prevents breaking gears in high-torque applications. Where is your info from?
                            Michael Spiegle
                            '01 Ford Escape / Daily Driver
                            '99 M3 / Track Car
                            '87 325is bronzit / wtf car
                            '06 Daytona Triumph 675 / Daily Rider
                              Unless this is a different "shockproof" (could be), it's typically a very light gear oil designed for minimum driveline loss for drag racing and qualifying applications.
                              Gimme a link to what you're seeing.
                              -Charlie
                              FYYFF
