How do you remove late model front valance?
  • bmwm3n528
    • 3654
    Sure this has been covered many times. Any help would be greatly appreciated.
    Thanks,
    Trevor Ely
    '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
    '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    • 34839
    unbolt it? :idea:
    it can't be that hard.. you have a rachet set right? you do need a T55 torx socket for the front bumper though.
    • Dirtsquirt
      • Nov 2004
      • 686
      with a tree....
      don't ask me how I know
      • bmwm3n528
        • 3654
        Originally posted by nando
        unbolt it? :idea:
        Well, that's what I thought...obviously the bumper is cake to get off. After that, I have no clue what ot unscrew.
        I unscrewed the bolt that's on the fender...
        ...probably didn't even need to unscrew it though.
        ...Now i'm stuck...can't find anymore bolts that can be undone.
        Again, any help is appreciated.
        Trevor Ely
        • kowalski
          • Jan 2005
          • 1791
          any clips i know the lip that comes on those has clips because mine got stolen so i can see all the clips and it fell off once and i drove over it.... dont ask... or check a manuel of some sort.
            • 34839
            pop out your grilles, there are more bolts inside there.
            • bmwm3n528
              • 3654
              Oil cooler grilles? or kidneys...
              Trevor Ely
                • 34839
                kindeys/headlights
                • Rigmaster
                  • 3464
                  You have to take out the bolts that hold the bumper side brackets on, maybe just the bottom one, but take them both off to be sure. Then there are 2 small bolts that attach to the front lower edge of the fender on each side- below the headlight. You'll have to take the grille out, then you should be able to see the top one, the bottom one should be a small torx bit. Then there are 2 8mm head bolts at the bottom, you'll have to take the brake ducts + maybe the fogs out to get to them. Then there are 2 more 8 mm head bolts that hold the top of the valance to the rad support. You will probably need a long socket extension to get to these 4 8mm head bolts.
                  Keep at it, you'll figger it out!
                  Bret.
                  • bmwm3n528
                    • 3654
                    Bret.
                    Yeah, I think it's down to the last 2 ... like two 8mm's that are connected on the bottom close to the radiator.
                    Trevor Ely
