Stomp code 1211
  • Strelok
    • Jan 2010
    • 280
    Stomp code 1211
    So my CEL is on all the time, and doing the stomp test gives me a 1211. I tried disconnecting the battery for a minute letting it run for 30 seconds, then letting it sit for 30 seconds, and it still gives me the same code.
    The only drivability problem I have is a pretty poor idle. It's around 900 RPM and very rough, the whole car shakes. Other than that it runs perfect.
    It's a 1987 325i with a 173 DME, Mark d chip. The engine is a 2.7 stroker.
    Thoughts?
  • selturk
    • Dec 2008
    • 1197
    1211 = DME Control Unit..
    Find information, resources and relevant links for e30world.com. This domain may be for sale.
    for the poor idle did you check your ICV?
      Since a power reset resulted in the 1211 reappearing, replace the DME.
