bmw fuel pumps are expensive, walbro?
  • Kershaw
    • 11822
    i've seen walbro 255lph pumps go from anywhere from 95 to 130. and that is significantly cheaper than the $187 for a bmw pump. also, i'd need 2 since mine is an early model. generally, installing an aftermarket fuel pump is no biggie.
    so my questions are:
    1. anyone install a walbro? any problems?
    2. how do i get rid of the exterior inline pump? obviously i cant just rip it out, it'll leave a gap in the line.
    3. is it possible to pull the line from a late model?
    tia.
    AWD > RWD
    I've had the experience of fixing a few "creative" solutions to the expense of the BMW pumps that weren't successful. So my recommendation is to pay the coin and replace with OE equipment.
    • Kershaw
      • 11822
      huh, i figured that most people who went turbo would upgrade the fuel pumps. didnt think it was that unusual of a mod. not that im going turbo (not in this e30) but i assumed more people had done this.
      edit:
      found this on bf
      apparently it does just drop right in, if you have a later model with a single intank pump.
      so i guess i just have to figure out how to remove the external inline pump safely.
      AWD > RWD
      • AlarmedBread
        • Sep 2006
        • 1510
        Basically the same as putting in the walbro.
        • bejbis
          • Dec 2008
          • 596
          Ive had bad luck with TRE pumps in the past, for the extra 15$ get a walbro. Ive had a few walbro pumps in different cars last for over 2 years and still going, one is over 7 years old and still kicking. The only TRE pump I had lasted 5 months and TRE wouldnt replace it under their 1yr warranty, kept giving me the run around until i gave up.
          I have a walbro in my e30, was a simple install and a over a year later its still running great with my m52.
          -Dan
          Originally posted by AlarmedBread
          http://r3vlimited.com/board/showthre...=tre+fuel+pump
          -Dan
          • StereoInstaller1
            GAS
            • 22679
            No, the one in the tank is only a transfer pump, makes like 7 pounds, just enough to feed the main pump.
            Closing SOON!
            Thanks for 10 years of fun!
            • Kershaw
              • 11822
              nice. thanks guys.
              edit: i meant i'd need 2 pumps if i went the oem route vs 1 walbro. i do know the 2 pumps are not the same. but they are similar in cost. ~$190/each.
              AWD > RWD
              • StereoInstaller1
                GAS
                • 22679
                I dunno why you would change the transfer pump.
                Closing SOON!
                • blueapplesoda
                  • Dec 2005
                  • 1904
                  yeah. its just a transfer pump. get an external if u have a 2 pump setup, and a intank if you have a single (late model).
                  walbro's are noisy as shit though. nothing beats the quietness of a stock pump.
                  • Kershaw
                    • 11822
                    i was going to convert to a late model set up. the car will never see track time (i just swapped the 4.10 lsd out for a 3.73 open. lol) so fuel starvation is not really an issue. which is the only benefit i see of having a 2 pump system.
                    but if you recommend leaving the intank pump (fuel transfer) alone and just replacing the external one, i'll go that route.
                    :up:
                    AWD > RWD
