Having some engine trouble.
    • 34839
    I would test all your sensors (CPS comes to mind, should be about 540ohms of resistance), coil, etc.
    electrical problems suck, I still haven't fixed my TPS. gotta rewire the whole damn thing too... yeah, make sure your TB isn't leaking coolant :P
    • Jordan
      • 12916
      I think my CPS packed up and went home.
      I took it out to have a good look at it, its definately toast.
      The big yellow and black wires look fine. The 2 small black wires, the shielding, and the rubber cord are wasted.
      pic:
      Looks like I need to hit Patrick up for one of these tomorrow.
      https://mtechniqueabs.com/
      • e30sd
        Fistee
        • Jan 2004
        • 5517
        http://www.bmaparts.com/epcksoap.epc...entid=bmaparts
        why are there 2 on 9/87-up?
        • Jand3rson
          • 37587
          n00b question: What is the CPS?
          • e30sd
            Fistee
            • Jan 2004
            • 5517
            crank position sensor
            • Jand3rson
              • 37587
              That's what I was thinking, thanks for the confirmation.
              Sounds and looks like the definite cause of your M20 woes, Jordan.
              • kowalski
                • Jan 2005
                • 1791
                i read somwhere about the fuel systems having trouble on E30's when its below half a tank some times, the pump can't hold the presure cause of less fuel, top it off or clamp the return line and see if she winds up, also im more partial to the chevron gas... anywho sounds fuel related, i have that problem as well but its only when i first start the car and its at the low RPM's not the the high... anywho good luck to ya
                • e30Matt
                  • 5077
                  Somehow I feel the picture he posted is the culprit, not fuel issues.
                  Jordan, if that doesn't solve the problem, maybe try swapping in a known good ECU.
                  • Jordan
                    • 12916
                    My in tank pump is new, and the outboard pump is not very old. I run my take till the light comes on all the time. in 9,000 miles or so I've had the tank more full then 1/2 once.
                    Ain't the issue. My money is on the CPS, I will order one tomorrow, should fix it.
                    • kowalski
                      • Jan 2005
                      • 1791
                      oops my bad i didn't see the second page to this form stopped reading at the first. i agree on the picture and on that note im going to take a look at mine tomorrow how much to those things cost?
                      • Jordan
                        • 12916
                        BMA price is ~$81.
                        • kowalski
                          • Jan 2005
                          • 1791
                          shitty those are expensive little buggers.
                          • Stu Mc
                            • 4083
                            bmw sensors usually are
                            • AndrewBird
                              The Mad Scientist
                              • 11898
                              My question is, will your car be ready for the meet on the 26th?
                              • Mot
                                45 toting redneck
                                • 4018
                                it better be lol..
                                Knowing Patrick and BMA it will be here in 2 days. Plenty of time for jordan.
