Some EVo m3's had 16x7.5 wheels with a 27mm offset, will these work on a regular e30 using the m3 suspension and a 225 tire?
E30 m3 wheels on regular e30
sure... as long as "using the m3 suspension" incudes EVERYTHING, meaning a full 5-lug conversion
(just wanted to emphasize that point cuz i'm sure there might be a couple guys who are new to e30 scene that might read this & not realize that the m3 is 5-lug & other e30's are 4)-Pete
LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)Comment
When Dave Adams did his E30 M3 brake/suspension conversion on his cabrio, he was able to run US Spec 15x7 M3 wheels (which have a 27mm offset) and shod them with 225/50 tires all around. He reported no clearance/rubbing problems although he suggests rolling the fenders just to be on the safe side. The 16x7.5 wheel with 27mm offset should be no different if you mount 225/45 tires on them.
I also heard somewhere that the E28 M5s used an identical wheel with the exception of the offset being 20mm. This could probably work on a standard E30 with M3 underpinnings. However, the 20mm offset will push the wheels outward a bit more so a 225/45 may not be possible. A 215 width tire may work.....and 205 width should be no problem.
JonRides...
1991 325i - sold :(
2004 2WD Frontier King Cab
RIP #17 Jules BianchiComment
Not to mention the conversion will cost you at least $1-2k.Originally posted by OreoGaboriosure... as long as "using the m3 suspension" incudes EVERYTHING, meaning a full 5-lug conversion
True. And not only that, the EVO M3's had wider than normal flares to compensate for even wider tires than the standard M3 could run.Originally posted by 808BMWDepends. M3's have flares that allow them to fit wider tires. If you have the suspension and rims, you might have some body clearance issues with no flares.Comment
trent
Stop the mis-information. They were not wider, just cut higher. :)Originally posted by Eurospeed88Not to mention the conversion will cost you at least $1-2k.Originally posted by OreoGaboriosure... as long as "using the m3 suspension" incudes EVERYTHING, meaning a full 5-lug conversion
