vdo, motometer interchangeability?
  • DaN
    • 1265
    If I currently have a vdo cluster in my 85 eta, will a motometer unit plug in and work? Or are the plugs and whatnot different?
  • James Crivellone
    Head Janitor
    • 6304
    As long as its the precoding plug cluster it will work fine. so 84/85 and pre 04/86 models
    • DaN
      • 1265
      So after 4/86 they used a coding plug? What does this do?
      I guess I can't use the one I found, it's out of an 87.
      Anyone have an eta cluster looking for a new home? or maybe a cheap source for odometer gears?
      • Bimmerfanatik
        • May 2004
        • 5349
        Can anyone else confirm this? My 1985 Eta can use any cluster pre-4/86, VDO or motometer?
        • BavarianBimmer
          • 951
          I've changed my whole 1984 VDO cluster for an 1987 Motometer
          and it should work too
          1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
          1997 E36 328iT
          1990 E30 325iT 24v SOLD
          1989 E30 325i 2.7i M-Technic II SOLD
          • pogiboy9
            • 475
            Same here
            http://www.decal-spec.com
