Updated, i replaced CV shafts, still clunking!
UPDATED again, 2010-08-09, replaced diff, STILL clunking!!!!!!!!
UPDATED again, 2010-12-07, tightened trailing arm bolts, NO MORE CLUNKING!!!!
This may concern the subframe OR the drive system, so i put this thread in General Tech.
Backstory:
JUST replaced ALL rear bushings w/ polyurethane, and ALL new brakes. BEFORE the subframe overhaul there was a louder clunking from the rear which was stimulated by driving over bumps, and it seems the new bushings fixed that, but now AFTER everything is back together (and working amazingly, btw), there is another clunking, which may have been there before, but I am not sure.
Symptoms:
A clunking from the rear of the car when quickly applying and releasing torque to the drivetrain, i.e. tapping the gas on and off, loading and unloading the drivetrain very quickly. I can do it while stopped in gear and releasing the clutch fast, or while moving by stomping the gas pedal.
Possible diagnosis:
COULD be CV joints, one of them has a BAD rip in the outer boot, but when jacking up the car and turning the wheel, there doesn't seem to be inordinate play.
COULD also be the diff, when parked, w/ ebrake applied, and in gear while engaging and disengaging the clutch quickly, the sound is hard to pinpoint, (while lying down behind the car), but it SEEMS to be coming more from the diff than any of the CV shafts.
So, can i tap into the vast knowledge base (and ass-hattery) that is R3V? ;)
Thanks guys!!
Backstory:
Symptoms:
Possible diagnosis:
Thanks guys!!
