While changing the timing belt...
  • Burnera
    • 137
    What else is sort of "right there" that's worth doing?
    Plan right now:
    Timing belt + tensioner
    water pump
    thermostat
    radiator flush
    silicone radiator hoses
    Rotating oil filter mount + replacing seal
    replacing oil pan gasket + adding oil pan windage baffle
    I'd like to remove the air conditioning stuff too, but i can't find the guide on here.
    Can you think of anything else?
    edit: only have about 10 hours shop time on weekends to do all this, the car needs to be up and running otherwise.
  • StereoInstaller1
    GAS
    • 22679
    Cam seal, cam seal carrier oring, throttle body gasket, clean electrical connectors everywhere.
    Closing SOON!
    Thanks for 10 years of fun!
    • Kershaw
      • 11822
      removing stuff is easy. just follow the lines and unbolt as you go. start at the condenser.
      AWD > RWD
      • 619E30
        • 1753
        Crankshaft sensor
        Originally posted by audiquattrot
        bimmers b4 b*tches....remember that.
        1990 Alpinweiss 325i - secret 500whp build
        2000 Audi S4 B5 Laser Red
        1990 Nissan 240sx - Drift Missile
        2006 CBR600RR
