Transmission issue
  • alpinee30m50
    • 647
    Transmission issue
    When im driving my car normally (m50 backed up by a g260) it goes into every gear just fine, but when im flooring it and shifting right before the limiter i really have to force it into gear, and sometimes it wont go in and if it does it grinds like a mofo. I have hs drags on friday so im trying to figure it out by then. I have yet to check my tranny fluid level. Any suggestions?
    Thanks guys,
    Jesse
    86 Zinno es
    M50 inside
  • kenika65
    • Aug 2007
    • 1336
    Use a friction modifier and if that doesn't help then your syncros are shot in the tranny,
    Dont forget why they double clutch!
    Give it a try and also think your gears are hauling ass when you are about to shift gears so let them have a second to slow down before tying to mesh the gears together or it will go boom if you drop clutch at the wrong time.
    1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
    1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
    • alpinee30m50
      • 647
      Excuse my stupidity, but wtf is a friction modifier? I dont really drop gears when i slow down i just put it in neutral and coast to a stop, the only time i beat on it is when im accelerating hard
      86 Zinno es
      M50 inside
      • alpinee30m50
        • 647
        Nevermind on the friction modifier i just got smart and googled it. So you just add it to your fluid?
        86 Zinno es
        M50 inside
          A change in fluid might hep, but my guess is that only a rebuild or replacement of the transmission is going to fix the problem.
          • alpinee30m50
            • 647
            Yeah im changin the fluid tomorrow on it hopefully thatll help
            86 Zinno es
            M50 inside
            • alpinee30m50
              • 647
              Well fuck me i changed the fluid and it shifts better now normally, but the problem persists. Time for a tranny rebuild i guess....
              86 Zinno es
              M50 inside
