starting has been an ongoing saga with this engine. its also slightly complicated by the fact that the head has a home ground cam.
dont ask me.. i found out when i had a valve adjustment done. btw, it adds absolutely 0 power and runs absolutely identical to any other e30 in the 1/4 mile.
so, the fuel pump was an issue. it made a loud buzzing sound and i figured it was due for a replacement. also, the spark plugs were bone dry after 5 minutes of intermittent cranking. so i bought a used unit on the forums. still didnt start. replaced the fuel filter. still didnt start. popped the line off the injector rail just to see if the maybe the line was clogged. fuel sprayed everywhere. pulled the spark plugs, they were drenched. good. at least im getting fuel to the engine. spark plugs looked like shit. and i've seen some shitty spark plugs, owning a rotary. i figure they are due for replacement. im also happy to find out that spark plugs do not cost $20/plug like they do for my rx8.
i did get the engine to turn on for 30 seconds and it even turned on very normally. not the usual low rpm/high rpm/stumbling rpm i got before. however it only lasted 30 seconds and i was not able to replicate it.
thoughts? i would go out and buy some spark plugs, but unfortunately the e30 wont turn on and the rx8 is in the body shop due to a pretty epic r3v. so im stuck here until my friend comes over.
dont ask me.. i found out when i had a valve adjustment done. btw, it adds absolutely 0 power and runs absolutely identical to any other e30 in the 1/4 mile.so, the fuel pump was an issue. it made a loud buzzing sound and i figured it was due for a replacement. also, the spark plugs were bone dry after 5 minutes of intermittent cranking. so i bought a used unit on the forums. still didnt start. replaced the fuel filter. still didnt start. popped the line off the injector rail just to see if the maybe the line was clogged. fuel sprayed everywhere. pulled the spark plugs, they were drenched. good. at least im getting fuel to the engine. spark plugs looked like shit. and i've seen some shitty spark plugs, owning a rotary. i figure they are due for replacement. im also happy to find out that spark plugs do not cost $20/plug like they do for my rx8.
