m42 with m3 tach swap - advice
  • robrez
    • Jul 2008
    • 3376
    I bought an m3 tach. I was planning on keeping my original tach and just swapping my gas economy gauge for the M3 tach's oil temp gauge. Now I'm wondering if I should use the m3 tach too?
    I have a MarkD chip, which raises the M42 redline to 7100, but is the m3 tach's upper rev end realistic? And would I need to re-calibrate it too?
    Not mine below, but the same, minus the red needles.
    January 2012 COTM
  • KenC
    King of Kegstands
    • 14396
    Bump, same question.
    I have a MarkD chip, too. I want the redline on my tach to be realistic...
    What is involved with installing an M3 tach?
    Originally posted by Gruelius
    • Kershaw
      • 11822
      holy shit. i thought all m42s redlined at 7500rpm. thats why everyone calls it a "rev happy engine."
      6500rpm.. you might as well use an m20.. im disappointed to find this out. big fail for an m42.
      s42b20 ftw.
      AWD > RWD
      • e304me
        • Feb 2006
        • 1374
        the gauge will not display right. When you are at 7000 the gauge will say 8k
        • KenC
          King of Kegstands
          • 14396
          Exactly what I wanting to know how to change. It has to be some sort of electronic module.
          • e30lyf
            • May 2007
            • 4516
            you need e30 M3 coding plug to work accurate.
            - Fercy -
            Classic BMW Specialists
            Santa Clarita, CA
            www.BimmerHeads.com
            • M-technik-3
              • 18946
              Why? If it has an M42 and it's a 4 cylinder engine then they should be compatible. Especially if it has the right codec plug.
              • xwill112x
                • Jan 2009
                • 4236
                use the right coding plug and the rpms will display correctly.
